gthoma23
86
Just wondering if they make spacers for the sprocket spindle to kick it out. my front sprocket is not lining up w/ the rear, and if i could get a spacer or washer to push the front sprocket away from the engine i think i'd line up.
thanks
2strokerfun
1,500
Nope. Sounds like you have a problem with your rear wheel. Could be wrong spacer on axle or bent swingarm. Most likely it is simply not aligned right on your chain tensioners.
gthoma23
86
well i found out the problem. when i was putting my bike back together, i somehow switched the collars in the swingarm around. the right side is about a 1/2" longer than the right, and i had 'em switched. so went through and changed them, and it looks fine.
thanx for all the comments though.
