showtime586
- Mar 28, 2004
- 512
- 0
I usually avoid this job altogether and have my local shop do it, but I decided to give it a try myself, but I have a couple of questions.
First, it seems that in one area of the tire, about a section 3 inches long, the tire beads are resting to far inside the valley of the rim.This is about 45 degrees from the rim lock. They don't "pop" out when the correst tube pressure is applied. Do I try and pry it out towards the outer edge of the rim, with the tire spoons, or do I just over pressure the tire and let the air pressure "pop" it into place?
Second question. Do you guys tighten the rim lock before adding the air to the tube or after? Thanks..:)
