tylerandreasson
- Oct 5, 2010
- 12
- 0
ok so i have a 1985 yz250 i just got, and the guy i got it from told me it needed new piston rings because the radiator got kinked, which it clearly was. so i took the top end off and i looked at it and the piston rings are pretty much gone on one side, almost like melted into the piston.. so i thought i could just buy a new piston kit, but someone told me since it is a 1985 that it is almost sertanly bored already.. so i looked on top of the piston and it says "mm .50"... does that mean it is at 68.50mm since 68 is the stock size? also the cylinder was scratched where the piston had beedn rubbing on one side. could i just get that honed? and then just put a wiseco 68.50mm piston kit in it?
tell me what you think..
Thanks,
Tyler
Thanks,
Tyler
