Timmay#678
- Aug 29, 2007
- 48
- 0
- Thread starter
- #26
Ok only found the macro mode on my camera so I've got some better close ups for ya!
crack in the inlet bridge:
Inlet lifter:
Camshaft:
Hey Rich, I fully understand what you're saying here, and this was the case with this engine from the marks on the exhaust side of the piston. However, from the damage done to the cam and lifter over one of the inlet valves, I'm assuming it was this that caused the engine to lock up. What would be the cause of this, could the inlet valve have stretched if the engine had overheated?
Inlet lifter:
Camshaft:
Rich Rohrich said:The piston chases the exhaust valve closed near TDC and if the exhaust valve doesn't get settled on the valve seat in time you end up with the exhaust valve closer than normal near TDC and they'll hit the piston. A sure sign that an engine is being over-revved and floating the valves is bent exhaust valves. Patman's son did the same thing on his hot rod XR95. Patman explained what was happening to him and it was never an issue again.
