mudfly
I have a 94 KX125 with a bad big end bearing, I ordered a repair book but I would like to get the crank out and on it's way to the repair shop ASAP. Here is where I'm at. On the right side of the crankshaft where the gear is I need to remove the nut. Is this a right hand thread or left hand thread? once the nut is off will I need a gear puller to pull the gear?
On the magneto side I have a remover being loaned to me tomorrow to remove the flywheel, is there another nut behind the flywheel?
or anything else on that side that will require a special tool?
Thanks in advance for any help
Rick
