I'm planning to paint my new shop concrete floor. There are some surface problems that concrete grinding should address. I did some research on the net and
know that a local company named Sunbelt Rental rents concrete grinding equipment. If you have done this to your shop floor I would like to hear from you. Good,
bad experience? Hints or suggestions? Any and all comments on the process. The surface finish of my concrete has some waves and areas where the surface is
not very smooth. I thought the surface finish should have been better but now I need to deal with what is there. I think the grinding process is the best solution or is
there something else I should look into?
