I am in the process of fixing up my yamaha 2003 ttr125l to sell. The back wheel has a little play in it so im looking at getting some new bearings for it. I need to know how to properly take the old ones out and the new ones in.
if its sort of the same as my yz85 theres a circlip under the seal just pop off the seal, and it should be in clear view not sure what side its on on the ttr but on my yz it was on the sprocket side you can get it out easy if you grind down some needle nose pliars thats what i did and it came out really easy took me about 30 minutes to change both
