there's nothing on the steering stem but right below is a metal plate welded to the frame with the vin # on it,it's the same color as the frame too.i just wanted to see if that was normal cause i have never seen that before.
Once upon a time, many years ago I had an unfortunate experience involving a vehicle that had weld marks around the VIN. In the eyes of the police, that meant that the VIN had been altered and therefor the vehcile was stolen.
None of my bikes have any welded on plates for the VIN, it is stamped into the metal that makes the tube that the front forks rotate in.
Indy: the VIN number should have been stamped deep enough that if you sandblasted them off I would worry that you have significantly weakened the frame! And for all legal purposes, you have now removed your VIN, a photograph of what it used to be is not going to be proof of anything. I sure wouldn't buy your bike like that.
